97 mach z 800 many piston seizures new cyl and pistons. temp stays too high but never over heats.cant keep temp down unless in deep snow.any help would be great.thermostat also replaced
Discussion Starter · #3 · (Edited)
after a cold seizure with slight piston damage want are the chances it will be ok or do you think i,ll need to rebuild it.Why when I talk to the dealers they seam like this sled is voodoo and tell me to get rid of it.
They say that because it's a triple, and the triples were riddled with problems, especially with the middle cylinder. I've got a 780 triple and it's been a good sled. If it had a mild seize, that means metal welded to metal. Might want to check into it a little deeper.
middle cly never had a problem always the outer two.some slight metal on one wall was told to clean it with some kind of acid forget what though.
King of the Universe
Muratic acid will remove aluminum from the cylinder wall. Be very, very careful when using it full strength. Use a Q-Tip to apply it directly onto the aluminum. Muratic acid is commonly available where ever they carry pool chemicals.
do the carbs have adustable needle jets or do you have to bye new ones.and do you know the stock settings!
