The people at M10 suggest to keep the limiter strap in hole #4 of the 5, I think you need to dial in your rear arm a little more. I dont have my setup sheet with me (at work) but the rear spring and FRA adjustment (that little slider block that the rear arm bolts to on the slide rail) have a lot to do with it also.
I was having trouble getting my sled to hook up from 20-30 mph and up on hard acceleration, it would always break loose and slide sideways, so I softened up the FRA block (1 full line on the hash marks on the slide rail) and put 2 full turns additional spring pressure on both front shocks (on the ski's)
On the FRA block, moving the slider block forward makes the rear suspension more firm, sliding it back softens it up, I slid mine back a little, which leveled out the rear suspension, but I didnt want to lose too much ski pressure.
I only took a quick blast down the private trail behind the house, but it seems much better.
M10's are a great skid, tons of adjustment, just keep notes on what you adjusted to where, so if your problem gets worse, or your main concern goess away, but a different problem starts, you know how to put it back, or split the difference.
