Seems like all the stickied resources are now dead links, so I apologize for starting a new thread... I had started asking about this in my primary post, but figured it warranted its own post.
I put my first mile (singular) on the 1995 XLT Touring on the weekend, and it wasn't doing so hot when I pulled back into the driveway. Sled had idled fine in the garage and seemed to run fine up on a stand a couple of weeks prior, primary had just been off for work so it hadn't been started in that time. Got everything back together on Sunday but it was tough to start initially - must have taken 15-20 pulls to get it turned over. Once idling it sounded fine. Took off, engaged properly around 4000 rpm, went up the field and back a few times, power was lacking a bit, so I took it back to the house.
Once i got back to the driveway I left it running for a second while I ran into the garage. Came back out and it had shut off. Got it started again after a ton of pulling over, and got it into the garage. I checked the plugs, they were all pretty wet, likely flooded from trying to pull over the engine, but I hooked up the compression tester and Mag & center cylinders were both right around 120, but PTO side wouldn't go above 90. engine was warm and compression was tested at WOT.
Carbs were removed, cleaned, reassembled and synced a couple of months ago before the season started - Air screws set to 1.0 turns per the manual. Idle was set properly to 1900 RPM. All seemed great in the garage before first ride. Carbs were marked to ensure they were put back in the same locations as removed from. Manual indicates same jets and setting for all carbs on the 95 XLT Touring engine.
Now my questions: How to diagnose the problem and then the likely repair?
- I've heard to spray starter fluid near the PTO to check the crank seal since it's that side that's low. If idle increases, I've got at minimum a crank seal that needs replaced, so I'm cracking the bottom end correct? If no change, then it's a different issue - check carb boots for sure. Could exhaust manifold gasket cause an issue also?
- Should I look at building a little leak down tester from a pressure gauge and some pvc/abs? There are a couple of different DIY versions I've seen.
www.vitalmx.com
www.dootalk.com
- The low cylinder itself - It's still holding some compression. Could be rings, could be the piston itself, could be the cylinder wall? What's the easiest way to diagnose the damage done in the best order? Look inside both the intake and outtake ports for any damage, look inside the spark plug hole? If nothing visible then is it disassemble?
- Just so I'm not setting any unrealistic expectations, I'm assuming best case scenario there's an air leak somewhere, gasket or boot that caused the issue, and then maybe rings in that one cylinder are bad and need replacement? Worst case I've got a crank related issue that will require bottom end work and then maybe a full top end - pistons, cylinder walls and all related gaskets...
Are any of these things beyond my beginner mechanic skills or is there anything I'd have to specifically bring in to a shop to do?
Thanks!
Leak down tester? (2 stroke)
What all is needed to build one for cheap? And how exactly? Also will a bike pump work instead of an air compressor? I know you only put 5-6psi or you risk blowing bottom end seals. How long ahould I wait as well? I saw one guy say wait an hour,...
DIY Leak down test. - REV Chassis - Performance and Trail Models
Page 1 of 20 - DIY Leak down test. - posted in REV Chassis - Performance and Trail Models: WHAT?? A leak down test is a compression test in reverse. Instead of measuring the ability of the engine to create pressure, we want to check its ability to hold pressure. WHY??? An engine that has an air...
- Is there an advantage to either style? the gauge on the second one is available locally and uses all parts I could find nearby.
- What exactly will a leak down test tell me? I gather it will show where any air escapes from the engine, one cylinder at a time? If I made the second one, that would test all 3 cylinders at once, correct - use soapy water to check for escaping air?
- If an air issue is found, fix before doing anything to repair the piston/cylinder.
Thanks!
