i just bought a 2003 pro x 700 and the chaincase seems to be a bit louder then my 800 xc's. Is this normal for this type of machine?
try checkin the tension and get everything greased up nice.
no automatic tension adjustment, and everything is greased and penty of chain oil which is clean. I guess I'll pound it until it breaks!!
YOU SURE IT IS COMING FROM THE CHAINCASE, COULD BE BAD JACKSHAFT BEARING OR DRIVE AXLE BEARING. EITHER WILL TRANSMIT THE NOISE THROUGH THE SHAFTS INTO THE CHAINCASE
GOOD LUCK!
Just a warning to you- I bought my 500 XC SP new in 2001. After about 400 miles I had to take it in because the chain wasn't adjusted correctly right from the dealer! I was happy because they fixed everything under warranty, but I didn't know until just recently when I replaced the chain oil that they never replaced the chain case cover. It doesn't affect anything, but it is all chewed up.
