while riding the trails the other day my mach dropped down to 2 cylinders with a few backfires... compression test shows 150psi left cylinder 50 psi center cylinder and 150psi right cylinder...... hoping its just replaces rings and go, i noticed oil leaking at the front of the engine where the jugs bolt to the crank case.. is it possible im loosing compression there?
