Still working on the snowmobile, found what I needed on eBay so far. Was wondering where the T goes for the primer, after the fuel filter coming out of the tank or after the pump, nothing in the manual shows it. I also took apart the speedo adapter and found a sheered off piece of key, I'm thinking the adapter got seized up a bit from sitting cause I can't get the speedo cable out of it. Bearing looks ok , greese is in there, how would I know if the bearing is bad? looks to be in good shape though. But the other side of the key is apparently stuck in the drive shaft.
