Like many, I have a clamshell trailer that has only the factory-installed "dome" light inside near the front access door. In my opinion, this is very inadequate and I wanted much more internal lighting.
I had toyed with a number of different options and ultimately settled on LED lighting strips that I would install overhead in the cover. I ordered up two 5 meter rolls of LED strip lights. What follows is my installation "so far", and will ultimately wrap up with the installation being finalized.
Here's a quick look at the front of my trailer from inside...
Pic 1 - Before doing any work
Pic 2 - Lens removed from the dome light
Pic 3 - Light unscrewed from the trailer frame
The reason that I unscrewed the light from the frame is because I will be tapping into the output side of the light switch in the back of the fixture. This will allow me to switch the LED strips on and off along with the dome light.
