I there a need for a piston ring depressor for two stroke cylinder replacement?
If so, is there a part number that any one knows so I see if I can get one?
LOL I have one save your money!
It is a cheap type.
The problem is the way the piston has to go in from the bottom it has to come off to slide it in.
The bottom of the skirt has a taper to it, that compresses the ring.
Get the rings lined up with the pins and set the jug on top.
Then push in on both sides with your finger tips, work one ring at a time and slide the jug straight down, dont twist.
Use plenty of oil as you install.
