I’m wondering what’s the best jet set up for a 98 XC 600. The sled has the almond gold and silver blue clutch set up with 10-64 clutch weights. Any good jet set ups would be awesome.
Factory jetting for elevation and temperature is usually a bit rich. But no one will tell you to swap from that, as then you are going against the manufacturer's jetting chart. If you want to vary, learn how to check piston wash and plug color and how to do plug chops so that you can do so safely. Jetting too lean will burn holes in your pistons. Trust me on that ;)
