GO GREEN OR GO HOME!
foremost the ole ladys f5 has a nice growl coming from the track area, sounds like a mud tire, little worse than the average firecat noise. 1 inch track 153 studs, bearings seemed ok when track was swapped, 1400 miles.... ideas? chain isnt too tight, track alightment and tension is good...???
her servo cycles 3 times on start up.....mis adjusted cables i assume???
my f7 isnt throwing codes but its only getting 7680 rpm. new belt and cables adjusted should help i hope.....valves are clean
