I'm going to get a clutch kit from black magic for my sled and was wondering if I need a clutch puller? How easy is the instalation I've never really palyed with the clutch but know the basics? I'm also going to get a 2" riser and need to know if I need to extend any of the wires and if it will be tall enough. I'm about 5'9" and I want to be able to stand straight up withought croutching and hold on to the handlebars. Thank you
I installed my first clutch kit without pulling it off. Alls you have to do is take out the 9 tower bolts that hold the primary together. Its a little tricky, but can be done. As for the secondary it should just pop right off. I would unbolt the handlebars and hold them 2 inches higher to see if the cables are long enough.
