Ok i took a job for a guy i know to get his indy lite 340 running ( he knows i am prity good with sleds and all ) and hes says it isent taking any gas in , any suggestions
i am thinking maybe fuel pump or lines need to be checked
anyone had this problem b4
yes, replace all the fuel lines and probably the pump, make sure it isnt a carb problem, what i do is take the carbs apart completly and soak them in carb cleaner all night long. that cleans em up. Make sure there is spark, i bet there is, but change the plugs anyway. thats what i woudl do
dano
Also, on my Indy Lite there is a valve on the fuel line that is open in the up position, closed in the down, we've had it vibrate closed once or twice in the past. It might be a good idea to chek for this first before you change the lines. It is pretty easily missed.
