I noticed the drain plug under exhaust to drain fuel is stripped on the clutch side. Bolt is good, but threads in block are stripped. Can gasket maker or something along those lines be used with bolt to seal? O do I need to re-drill and tap block? if I need to re-tap, can this be done with out pulling motor and getting any shavings down in the crank? Thx
