How tall of lugs for that track how high can I go wit them. Is there a clearance I need to worried about or no
1.25" without studs .91" with studs. Some have claimed to do 1.5" without studs but I have never seen it. Also it depends on the year of the sled. If you have a '95 or newer with the Xtra-10 or Xtra-12 the chances are better you could go with the 1.5" paddle without studs. But if it is a sled with the lower 8" meaning some '95 models and before of the XLT don't even try it. Best you can go is 1.25" and even then I would be scared of it hitting something. I did a .82" with 1" studs on a '93 Indy 440 L/C and in order to do it I had to remove the seat then drill out the pop rivets holding on the tunnel strips. IF I would to do a track change now on my '97 Indy 500 L/C I would go with a track with studs built in like this one. Saves time and money when doing studs. Just remember if you do studs you need carbides.
