I have a 1995 Indy 500. It floods out immediately as soon as you try to start it. If the plugs are dry, you get one quick pop. A friend tried to borrow it from me and gas was running out of the exhaust pipe. It was running earlier this year. I cleaned the carbs, but, am I missing something?
Stuck float maybe?
Hard to start one on one cylinder so even if one is flooding it will cause problems. Yes, i have seen both floats/chokes stick so clean them both.
if it flooded that much you will have to drain the crank case.There is a 10mm bolt under the y pipe close to the bottom of the block,there should be one for each jug,if there is alot of gas in there it wont start,something to try good luck
