My young son has a 2004 AC 370 not running 100%, i'm cleaning the carbs now but was also concerned if his ignition wires are correct, the longer wire is actually on the plug closer to the coil and the shorter wire is the far reaching plug. Does it matter? The wires are attached to the coil up and down so if there is a correction can you tell me where the "top" wire goes? Thanks
