here is the story I have a 1972 bombardier valmont alpine witch I have a 900cc 3 cyl kubota diesel in that I will be machining a adapter for to mount a p85 polaris clutch on becasue they are easy to work on and I have a relatively new one on hand, the chain case is a modified yamaha vk 540 chain case so I have high, low and reverse and I am using a yamaha enticer 2 secondary clutch and jackshaft because its what I had on hand and the enticer 2 jack shaft had the same spline and the vk chain case.
so now that you all know I'm crazy and what I have built I need help with the clutching, for the diesel I need the clutch to engage at ~1000RPM and I would like for it to hold ~3000rpm while driving. max RPM on this engine is 3600. so if anyone can point me towards what weight spring to use and what weights to start off with as a baseline that would be great becasue I am lost in the dark on this one.
here are some pics. dont mind the mess.
still need to shorten the jack shaft.
