My problem is that it started up normally. Once it warmed up I started to take off it backfired a couple times and then started to move. It made a whinning noise but took off but when I slowed down again it backfired and then died. How do I fix this issue
Welcome
Start with simple stuff
Compression
Air leaks
Reeds
Reed plugs and piston tops
You DID clean the carbs this Preseason right?
My 94 vmax 600 had the same problem, and it had a blown piston. Hopefully it isnt as bad. Sounds like atleast one cylinder is firing, I would check spark and then compression.
