Hello everyone I’m new to the sight. I have a square style double outlet mikuni fuel pump and recently picked up a rebuild kit. Wondering if anyone has a diagram. Thanks
I wouldn't be worried about a diagram. Fuel pumps are dead simple, but I could be wrong. If you can't find one, take pictures while taking it apart so you know where everything goes
#1 if you didn't clean it while rebuilding it, boil the metal parts in lemon juice water.
#2 try pressurizing the gas tank and make sure that fuel flows through the lines. If no fuel goes through then you need to replace the lines.
#3 if the lines are old or cracking, you might need to replace them, especially the vacuum line. Even a tiny crack or leak will make it inoperable.
Hope this helps
