1992 Phazer Mountian
Well my sled is idling low and when it's moving rpm's are high so I lost 4 days of knocking around in fields then the snow was washed away by rain so does anyone know what could be wrong with my sled or can you tell me good stories to make me feel better :confused:
well try to be a little more specific it almost sounds like a clutch problem but more likely is carburation issue have you cleaned carb this season and is belt and clutch in good shape
Yeah the carbs are clean it sounds normal it's just idling low and when it's moving the rpm's are high and the clutch engages early so is it probably the clutch?
