just got my 800 triple running in my 01 mach and i bled the oil pump as shop manual says with the screw on the side... and my 2 lines are lined up on the oil pump lever and body.. manual says i should see the air leaving the small individual oil lines going to each cylinder but the lines are a dark blue and cant see oil moving i am just paranoid about this engine i want to make sure everythings perfect and the oil pump is working as it should before i leave my driveway
thanks
connor.
thanks
connor.
