1 - 9 of 9 Posts
how much lube will go into 93 ext 550 mtn cat chaincase i dont have a book on this sled should i just fill it to the top or what any help would be great.
i put 1 qt in and it doesnt show on the dip stick. but the stick is only about 1/2 inch long and magnetic should i put more in?
If it doesnt show up at all on the dipstick then i would add a little at a time until you can find out how much you need until its full.
Ski Doo's require 7oz. Filling it is WAY too much. There should be enough for the chain to ride through as it goes around the bottom gear.
The dipstick should be showing with that much in there. Its hard to say whether or not to put more in because you could have other problems; like its all leaking out the back???????:rolleyes:
I dodnt see any leak any place i ran the sled back and forth in the shop and there is no puddle so I dont think its got a leak?
A quart! That can't be good. The dipstick goes in the lower hole not the top one.
1 - 9 of 9 Posts
