1 - 13 of 13 Posts
I just picked up a 1996 Ultra SP and I going through the whole sled. Adding grease to the jack shaft and any where else I can find a zerk fitting.
I also want to change the crank case oil but I'm not sure how to drain it. Fuel filter will be replaced, also is there a crank case filter that needs to be replaced??
I'm not to familiar with that sled, but , if it's like any other sled ( until recent years) it's a 2-stroke.....No oil/filter to change!:confused:
If it's a 4-stroke then I have'nt a clue.
he said crank case, not engine oil. So yes there is a problem for him. He needs to change the crank case oil, somehting I dont know how to do myself.....
Looking from UNDERNEATH the sled find the chaincase area. You will find that the belly pan has a circular hole in it. About 1" up is a allen head flush mount screw that threads into the bottom of the chaincase. Be careful, you will more than likely need a metric allen head driver or wrench to loosen this screw. If you use a SAE size you can strip the inside (part that the allen head driver slides into) out of the screw. Been there, done that.
Is there a crank case filter if so where is it .
What in the world are you guys talking about! Does anyone know.
i think they mean chaincase, no filter but you drain it just like that guy said a couple before me, and if you didnt know its on the right side of the sled
Pre- 98' I don't think you'll find what accobra66 was talking about. With the chaincase just pull the 4 mounting bolts & make a mess... Its only like 12-14oz or something like that, so just have a couple shop rags available. Polaris was smokin' crack with that design...
There is no filter or pump with the chaincase. Just oil sloppin' around in there.
If your looking for a crankcase filter. With a 2 stroke moor it is a dry environment. Nothing is but air in there.
Discussion Starter · #10 ·
accobra66 is correct there is a allen bolt drain plug.
Thank Guys
That maintenance is supposed to be done once a year (Polaris). If you guys see, that oil is dirtier than hell...someone told me it was due to the stock "powder" gears.
Jon
My 94 Indy Storm Has no drain plug just open case and make a mees out of things
the dip stick should have a magnetic end to pickup any shavings if yours dosent have one get one
I use a suction gun about the size of a grease gun to suck most of the oil out of the case before opening it, that way there is a LOT less mess to clean up... you definitely want to remove the cover so you can take a look at the gears and chain, some times you find surprises!
1 - 13 of 13 Posts
