I have a 98 xlt classic 600. One of the studs has pulled out an thir is a quater sized hole on the track. Should I replace it? The rest of the track is good.
Gary
Depending on where you are, you may be able to get the hole repaired. It can be repaired as good as new these days.
yea it should be fine, just do what SEG said, to try it and if it doesnt work, just get it repaired
Where abouts in the track is the hole?? Middle or on the outside?
if the hole is on the outside then you may have a problem. If it is in the middle belt, your fine. I was reading in an issue of snowtech magazine that polaris has recently been testing sleds where they drilled out like 200 or so 1 inch holes to lighten up the track and it has worked with no failures for them.
Hole in Track
The hole was on the outside. I decided to install an Ice Claw Track. For the $400 it seemed to make sense.
