Hi I have a 1991 ski-do 380 with a seized engin. Would it be better to get it fixed or just buy a new engin. Also could you put a 500 in it with the right adjustments insted of getting another 380 engin. Thanks Al
Just cause it seized doesn't mean its junk....You can fit any motor in anything with enough time and money, but fit corectly?Well i don't know much about ski doos. You should take the motor apart and see if the sides of the pistons/cylinder walls are scared, Did you over heat it???
I got it off a friend. Im not positive what he did to it but he seized it last sunday. So once I get it apart ill see if its worth fixing. If not, try to find a bigger better motor that will still fit in the sled if theres one out there.
