Hi, I have a old 1987 Arctic Cat 440 jag. It runs good but it bogs down and dosent have all the top end sometimes. Sometimes its awsome then other days its a pig. Is there anything I could check or do I just bring it to a shop. Also im getting a 1991 ski-do 380 with a seized motor. Would it be woth trying to fix the motor or just getting another engin. If so could you put a bigger engin in it like a 500 or would you have to keep a 380 size in it. Any help is apprecitated. Al
Depends what seized in the motor (piston or rod bearing). Piston a lot cheaper to replace than rod/crank. And WHY did it seize? A 440 or similar should bolt right up.
As far as the other sled, I'd check the crank seals to make sure that's not it.
Im not sure quite yet why the engin seized. Were getting it for free the guys sun seized it last sunday. Thats all I know. About the arctic cat its just idleing very low now, so lw that it kills itself.
