Have 1980 artic cat panther rebuilt fuel diaphragm pump last winter and had to fill fuel lines every time to get it going. this year filled up lines with fuel and it will run till that fuel is used up but will not pull anymore out of tank. Replaced all fuel lines and vacuum line. Put finger over vacuum line while sled was running and it had a little suction. Do you think I need to rebuild fuel pump again or what.
Find your tanks vent line (by clutch?)
Simply blow into it with cap on and fuel lines off, till you get gas out
Then with the plugs out if you want, pull it over and see if the pump is working
I’d simply replace pump. I think I paid 25$ for mine. Make sure your lines from tank to pump are in good shape and from pump to carb. I put a small fuel filter on mine before the pump. Also make sure your line in tank is submerged in fuel. I had one a while back that wouldn’t run with a half tank of gas or less.. upon investigating the end of the line was sticking up out of fuel... and oddly enough it would pull fuel intermittently.
