I was aligning my skis the other day on my 05 switchback and it turned out my left side inner tie rod end was rusted/corroded into my tie rod itself so when I tried to turn the rod, the tie rod end snapped off inside.
Polaris lists this part as 7061085 or #5 on a parts diagram
I went to my dealer looking to get a replacement but I was informed that they don't make this specific tie rod anymore.
I'm wondering if I could use the tie rod 7061075 instead? #10 on a parts diagram.
The dealer said it might work as the threads are both left handed. The only difference I've found between them is the 075 is listed as hi-angle.
No you can not go to a 7061075 as that is a hi-angle and will not adjust properly.
There ya go a whole new assembly with new tie rod ends for 54 bucks if you want to go that route. Which I would if it was me since over time that stuff corrodes.
What you need is a tie rod end with 50 degrees with a size of 3/8" by .750 length with left hand threads. There has to be another manufacture or aftermarket that makes it.
Lot of manufactures use the same tie rod ends on sleds just a different part number is all. Hopefully this helps in some way, yeah ordering from eBay and having to wait for a few days stink but it might be the best route with some tie rod ends going from 10-60 dollars and that is the whole assembly for 54 plus 7 for shipping. Nice thing is eBay has 10% eBay bucks going on right now if you activate the coupon.
I just ordered that one. Says he builds them to be more heavy duty than the original. We're not supposed to get any new snow for a little bit around here so I'm fine with waiting the week it'll take to get here.
Anyways, what's the difference with the high angle end for future reference?
Thanks.
It could have possibly worked but why take the chance? Better to be certain when it comes to steering parts imho.
