I have a 98 pantera 2up and when I turn my key the fuel pump was not pumping it's anitial pump. The lights all came on. It will starts but idles a little ruff. When I hit the throttle it bogs out and dies. I have traced some of the wiring and found at the fuel pump harness if I take a wire from the neg. side of the harness and take it directly to the neg. side of the battery the pump will run and the sled runs like it is suppose to. I looked at some diagrams on the net and fond that the harness said it had a resister in it. Could that be the problem. I have also traced some of the wires to the ECU. Could this be the problem. If anyone has any suggestions I would greatly appreciate it. I feel like I'm at a dead end.
Thanks, George
Thanks, George
