I have a 73 Yamaha GP338 (twin carb). It has 421 original miles. I rebuilt the carbs about 10 years ago and used it for a few winters then stored it with sta-bil. Last winter I could not get it to run, so I drained the fuel and put in fresh fuel and sta-bil and put in new plugs. I just disassembled the pump portion of the carbs and the float level needles in both carbs were stuck.
Currently it will start and idle around 2k rpm but when you tip into the throttle it will rev up, but only to about 3,000rpm max and after 2-3 seconds at that speed will start to lose RPM and die. If you give it full throttle when its idling some fuel spits back out of the carbs and it just makes a 'blaaaaat' sound and does not rev up.
Any tips / things I can check for would be appreciated!
