I did a RMK seat/tank swap to my 02 XC 600 and installed a Skinz LED brake/running light. I connected the 3 wires to the stock taillight wiring. The brake light is bright and works fine but I am having an issue with the running light not working at idle and when the sled warms up it works when it is around 4k RPM and is bright. I am wondering if the voltage regulator could be bad but I am not sure. Any suggestions are appreciated.
