Something for you to check (which I found out on mine - 93 500 EFI) underneath the padding on the right handlebar I found the connection unplugged. Plugged it in, turned on the toggle switch and it worked, I checked for a battery drain when it was not running and it was ok. I also checked for any breaks in the wire and for it grounding out - none found (it's very easy to trace the wires). Hopefully yours is a simple as that.
