Cant say specifically the spec, one of the manuals you can download from here will tell you. It will be in the 25 to 30 ft lb range, just did my xc600 and it was 24. as memory serves me the RXL has individual heads, probably 6 bolts (or nuts on studs) and you would stightne them in a start pattern, NEVER go around in a circle. On sleds with a single head for multiple cylinders you start in the center and work your way out.
The reasoning for this is, if there is even the slightest bit of allowable warp, you want to work it to the outside. Kinda like applying a sticker to your hood, you start in the center and work the air bubble to the outside.
