1 - 13 of 13 Posts
I try to find the good riser for me.
I have a 04 RMK (gen2 frame)
I'm 6 foot tale.
I'm not sure if it is better to put a 3inch block or something like a pivot stile
Someone have try bot?
Look nice
The pivot risers allow you to move the bars a bit forward so your weight can be more toward the front. Straight risers move you back on the running board a bit and make the back end heavier. I had 4" of straight on both my Edge RMK's, there were times when I would want to get the nose down so I would move forward, but then steering was interesting because you get very close to the bars. The straight ones worked ok, but I would have liked to have pivots in those cases.
I,
I would like to put an extension for brake line but it is like a 45 degrees, but Powermadd have a straight or 90 degrees, Some one have made a test with one of these, I don't know if he have the 45 degrees. so witch one fit on a 04 rmk edge model??
Thanks.
Discussion Starter #8
In my old life, I had this tool and hose but now I don't have any. :O(
Discussion Starter #10
How you do yours, because it is a flexible line not a rigid one, do you have a pic of your setup.
I can maybe put a male - female hard extension 6 inch line from the caliper, how you do yours.
I try to be most clearly, I speak usually french .
Discussion Starter #12
Ok I will check to find the fitting
1 - 13 of 13 Posts
