When you did the steel line did you put it on the bottom or the top. Also did the Throttle cable reach or did you get a longer one. I have a 2001 RMK I have a three inch extended post and I'm going to put a 4 inch angled riser on top of that so 7 total. Just want to have everything in order to pull it apart and put it back together fairly quickly.I see. I was able to put a 6 inch riser on my sled but it made the brake line a smidge too tight. I extended it with a custom made steel line I made at the shop. You should be able to put a 3-4 without any issues.
