1 - 20 of 23 Posts
Hi, great forum!
I just picked up 2 1985 Yamaha Phazers, KITT and KARR. They are reversed in the pic.
Picked these up for $600 and the plan is to get them running for playing on my property and around the neighborhood.
Plant Tire Vehicle Automotive tire Wheel
KITT needed the carbs cleaned out, a float was stuck. I got her started but gas was pumping out of the overflow…The oil/gas lines are all hard and I have new lines in hand with filters coming, along with a windshield. The seat is in good condition, the plywood base needs changing out though.
KARR needs a new fuel tank (ordered on eBay) as the cap hinge is broken. Obviously needs carbs cleaning and new fuel/oil lines. Not touching it ubrill KITT is running, need a reference..
Both have had the gas and oil tanks drained and I already picked up new batteries and a set of new bulbs for each.
Both need body work and I am sure the shocks and steering all need work.
I like playing with old machines, I have a 1982 Bronco, 1984 F350 and a 1985 F150 I spend most of my free time working on. When my wife lets me!
Wheel Tire Car Land vehicle Vehicle
Thanks for the welcome! Sunny Kfalls! Not too far away!
I didn't realize how much of a following these old Phazers have.
Honestly, about 3 years ago I nearly bought a nice condition one for $800, just to play with at my property. But it felt like a lot of money for a toy, so I bought my Bronco for $900 instead.
When these 2 came up for $600 for the pair I couldn't say no.
The look of these machines is so quintessentially 1980's. Just bring your onesie and walkman!
I don't think it will take much to get these up to a good standard, this forum has been a valuable resource to get as far as I have. My friends (from out of town) are already exciting to come visit this winter and rip around :)
Supporting vendor
Welcome to the forum, @GSMBlue
Good luck with your project!
I have one of the machines complete. Please meet KARR. I am particularly proud of the keyring. KITT has an appropriate one too.
The hardest work (for me) was actually removing and replacing the carbs. What a total pain. Rebuilding them was easy. The fuel lines were nearly as bad to fiddle with. There is no space in there and I swear this thing was designed by a left handed engineer with child sized hands.
So I think the list of work is:
Rebuilt carbs
New spark plugs
Replaced all fuel lines
Replaced some oil lines
Replaced wooden seat base with plywood sealed with poly eurethene
New visor
Painted the dark grey panels light metallic silver
Painted rest of body gloss black
Patched holes in the hood
New hood sticker
New headlight bulb
New headlight switch
New LEDs for dials
New battery and hold down
Replaced wire that hold the hood open
Cleaned and painted the metal skis
New carbides
New ski skins
Lots of new fasteners
Cerekote all the plastic bits
I do have some overspray, this was a rattle can job outside in the cold and wind..
The steering has major slop but the steering bushings look like they are a pain to get to, so that won't happen until I run out of other projects!
Plan is to push this one outside at the weekend and bring KITT in. I think KITT will go quicker as I ordered 2 of everything when I got parts for KARR.
Anyhow, a couple of pics. I have tons of the work but the end result is what matters.
Tire Wheel Vehicle Motor vehicle Automotive tire
Tire Vehicle Automotive tire Automotive lighting Wheel
Motor vehicle Automotive tire Hood Automotive design Automotive lighting
Nicely done! My only suggestion would be to ditch the steel skis with skins and go plastic well that and studs if you plan on running the trails. You will lose 20-30lbs off the front end making it turn 100 times better and it will not feel as "heavy" turning it. It makes a world of a difference!
Administrator
God help you at DMV. I have had to deal with them a couple times this year. I had to take a trailer in to get registered, it was from out of state; they have to read the VIN to get a title transferred. So I had to make an appointment, then wait for 10 weeks before my license plate showed up, and another few for the title. Next was an older Jeep Wrangler I bought in September, I did all that online and am still waiting for plates and registration/title. ODMV is definitely NOT on my favorite places list ;)
Discussion Starter · #12 ·
Noted on the skis. I did see nice plastic skis on my friends more modern machine. If I had know before ordering the carbides and skins I would have. live and learn!! Maybe an upgrade for next year.
As for the DMV, Why do you think I have been putting it off for so long! I will have to go at some point, maybe tomorrow morning...??
You can do the upgrade now. A cheap but really nice option would be the Camoplast trail skis with 6" of carbides for when you do studs. All told figure around 250 with the skis, mounting kit and carbides as they use carbides from certain year Ski-Doos and Polaris Machines. There is a local place that sells them on eBay you could email them make sure that they have the kit you need for those year snowmobiles and get them while you can since stock is so hit and miss. I have a set of the trail skis on both my Polaris snowmobiles and the difference was so dramatic all more then 10-12 years ago I thought I was driving a completely new snowmobile.
Discussion Starter · #15 ·
Thanks for the info Coolhand, my budget is tapped for these two for the year, I need to finish the interior of my 1984 F350 and that will eat the last of my play money. I paid $600 for KITT and KARR and I am in for about $600 more for all the parts I had to buy. If I could go back and do the plastic skis I would. I literally knew nothing about snowmobiles 20 days ago and know I only know a little more!
I don't think I will get KARR on snow before thanksgiving. But soon after, we need more snow!
Bah tell the wife it will be a worthwhile upgrade that makes it easier on her to steer and enjoy snowmobiling. And tbh it is everything I said in the previous sentence,lol. Remember a happy wife means you don't sleep on the couch that night!
Administrator
Pick a nice day, make sure she has good gear on to stay warm and dry... nothing kills the interest than being totally uncomfortable on that first ride. Or find a cute girl to go riding with... that works too :D
1 - 20 of 23 Posts
