hi folks, the grip warmers on my brother-in-laws 2000 mxz800 are not working, when i turn them on the headlight dims and the tach stops working. the thumb warmer is working fine. it has power going into the switch, when i turn them on on hit it with a test light both the high and low tabs show power no matter if the switch is in high or low. i though to find and clean the ground but cannot find it. thanks for any help you may have to offer.
common issue.that 2000 still had old style of tape grips. some 2000s and 1999s had wires runnin thru handlebars and around to grips (especially if rider put hooks on sled) wires would cut and ground out there all the time. otherwise ground conection probobly came off on handlebar tape under grips. heat grips w a hairdryer to get um off easyer to look.
