what are the chances of a gas tank actually cracking i seem to be getting a little gas in that area from somewhere but the tank is in pretty good shape, a little rust in the bottom but nothing horrible. and i cant get under the tank to look actually i cant get the tank off at all . should i worry alot? should i get a plastic one?
You don't mention what sled you're talking about, so it's hard to help.
Regardless, most tanks have a "vent" hole or hose. Could you be seeing fuel from that? How full does the tank have to be for you to see leaking?
depending how old the sled is, it might just be a good investment to get a plastic tank. (also depending on price).
yeah, rgoers is probably right... maybe it just overflows and comes out the vent hole or hose. how much gas is leakin out? if its a liitle bit, definately check that out.
