1 - 1 of 1 Posts
My friends 97 indy lite is leaking gas and when i went to look at it i could only see gas in the belly pan and right under the gas tank which makes me think the gas is leaking from the tank itself. nothing else was wet at all (carbs, fuel lines). i looked from the front and behind the steering shaft i could see the fuel line coming off the tank and it looked good and was dry. I could see where the tank meets the chassis and it was wet. Is there anything i overlooked? something else i can check? If it is the tank does it just have to be replaced or is there a way to fix a plastic tank? PS. the sled was not run this year and not even pulled over. fresh gas was put in and the next day gas smell and a small puddle. Thanks for any input.
1 - 1 of 1 Posts
