87 indy 400 what will cause the gas to leak from the hose where it goes into the carb would that be the choke stuck open. the thing wont idle down
it could be that your float is stuck. try cleaning the bowl or tapping the carb lightly with a rubbermallet or a screwdriver to free it up.
Replace all your fuel lines. I have an 87 Indy 400 that's just got nasty fuel lines and man did it leak out everywhere.( You'll be much happier after you spend a bit of time fixing lines and everything works again.))
