I have a 2019 Skidoo MXZ 600R etec. I am trying to install a Garmin Montana 680T along with a dash mounted plug for heated visor. I plan to use the Garmin cradle and wiring harness. I have read that that there is a Y wiring harness that is plug and play and allows installation of two 12volt accessories. I don’t want to splice these accessories into the Skidoo’s wiring harness. I emailed Leaders RPM asking the same question. Their parts dept called me to ask exactly what model Skidoo I had. He told me that there was no Y harness for a 600R etec or the Sport. Very strange that skidoo’s wiring harness would be that different. Ski-Doo New OEM Accessory Plug & Play & Harness Cable Adaptor sold at amazon is what I thought would work. Any thoughts? Thanks for any response.
Yes, some are different. Lots of times one is AC in the wiring and if so then you'll need a rectifier and regulator to get the voltage correct. I have made up regulator circuits in the past to do just this but if you are not handy then you'll need a plug and play method. Look around some more for something that will work or tap into the wiring to do it.
Steve
PS. Like one of these possibly.
Steve
Thank you
