The fuel pump is driven by pressure/vacuum from a hard rubber hose that comes from the crankcase. The pressure/vacuum created by the piston going up and down in the cylinder creates alternating pressure/vacuum in the fuel pump that acts on a diaphragm in the fuel pump. That is what drives the fuel.
If no fuel is coming out of the fuel line that goes to the carbs, you could have a ruptured diaphragm, a bad impulse line (the hose from the crankcase to the fuel pump), a plugged inlet filter on the fuel line in the fuel tank, or rotten pickup hose inside the fuel tank. I would also check to make sure there isn't a fuel shut off on the line from the fuel tank to the fuel pump.
The oil pump is separate from the fuel pump.
