1995 arctic cat zr 440. Sat for a while started yearly…. it did start and run recently to warm up.
Replaced needles and seat with viton tips / the seat was shorter with holes in the seat. 3 holes vs no holes in seat. The viton tip was a tad bigger.
cleaned all carbs
Rebuilt fuel pump
Added a gas shut off inline
Put all back together/ won’t start.
it pulls / sounds like it wants to start then won’t. 2 cups of gas in muffler
prior To this/ gas was in cylinders and exhaust.
pulse lines is a soft rubber
I’m using a cottage cheese container with for gas. Also replaced pick up line. Tank is currently off. No gas going to carbs and After 30 pulls gas in cottage cheese cup was not going down l. Definitely not sucking. I was told psi was good in both cylinders
bad crank seals ??
cleaned all carbs
Rebuilt fuel pump
bad crank seals ??
