I replaced the rotors and brake pads on my truck. I also replaced the caliper on the drivers sidec because it didn't slide on the slides like it was supposed to. I am wondering if the bolt that holds the brake line into the caliper would have expanded due to the heat, because there is a leak coming from the bolt. If you have any suggestions they are greatly appreciated. Thanks.
Yes I put the two new washers given with the caliper, so maybe I should try the old ones?
i hate to ask but was it clean when put back and/or check for a crack on the lil block that bolts to the caliper. is the new caliper compressing and decompressing correctly?
CLean it all off and see where it's leaking. If it's leaking by the washers, make it a little tighter. They have to be compressed slightly to seal.
