2 questions: how often does the Fox rear shock on my 2000 Indy 500 XP XC need rebuilding, and what is a good indication you need a rebuild? The sled sat for 2 years before I bought it, runs great, has the extra 10 suspension, but last season, I noticed even a small field approch jump felt like it bottomed, I admit, I don't have a lot of ride time on sleds, but I thought the extra 10 would be a litttle more plush than that. Thanks for any tips or advice !! I'm loving the fall so far, but am getting that itch to ride some powder !!
Team Arctic
i would try getting the shocks recharged, they often get water in the shock oil and lose some pressure. they say you shoudl do them every year, but i just watch mine. you can tell, they just start to feel different
Once a year is what I've heard also, but a sure sign is any oil leakage, or remove the shock and cycle it by hand. If you can go full stroke It definately needs help. The shock should have a smooth increase in resistance as it's compressed. You won't be able to fully feel a bad shock by hand, but if it slams 1/2 way down with no resistance, it's done. ( <--- That's where my shock is right now, getting a re-build.) My shock CLEARLY needed done because it leaked oil during the summer, and had the symptoms I described above.
Thanks, guys, I'll pull the shock and check it, may check the fronts,too, but they seemed to ride fine, but it can't hurt to check them all.
It's time to get my Fox shocks done and being I just bought my sled I've never had it done before so where is the best place to get them rebuilt?
