hello I have a skidoo formula stx 583 1996 I have an electrical problem, the coil is good but I have no spark , do you have an idea where to start to do my research
disconnect the black wire coming out of the stator and test the spark again. If it still has no spark, then check the spark plug cap (easy things first).
You can check the voltage going into the coil and see if there is anything. It should be between 35-60 volts AC. (actually pulsating DC, but use AC on the meter).
How do you know the coil is good? If it is indeed good, the only other thing is the stator. I'm pretty sure on that machine you can disconnect the harness from the engine to eliminate any outside items (key switch, etc) and you'll get spark. If you do get spark, there is something in the harness that isn't good. If still no spark, coil or stator.
