I'm ready to pull the flywheel on my 1972 elan 250, 247 engine rebuild and would like to know the best puller for the job. thanks in advance!
Looks like you will have to make one!
Start6 with 3 6mm threaded rod nuts on those studs
Then using the cage that goes on those studs as a template, drill a piece of 4'x4' steel
With just the nut on shaft (remove washers) put steel on and 3 6mm bolts.
Tighten the bolts and give plate a tap, tighten tap, tighten tap POP
It will scare you when it goes.
