I measured compression and it was 65 psi in each is that piston rings i have almost 11 on it and have done very minimal maintenance on it other than plugs does piston rings sound like the problem
I think you might need to clarify your question. You have almost 11?
Does the compression tester work correctly?
What's the exact sled?
Is this a new problem after running fine for a while? New issue after a rebuild? What symptoms of issues was the sled having before testing compression? Does it still run at all?
