Is it neccesary to keep the stock heat sheild on your pipe or does it only prtect your hood from the heat?
Also if your pipe leaks is it burnt out, and will it take out the engine on a sled with DPM?
I WOULD RECOMEND LEAVING THE SHEILDS IN PLACE, AND YOU DONT MENTION WHERE THE PIPE IS LEAKING. IF IT LEAKING AT A JOINT TRY NEW SPRINGS, IF YOU HAVE A PIN HOLE IN THE PIPE YOU SHOULD BE ABLE TO MIG WELD IT AND I DON'T THINK YOU WILL HAVE A PROBLEM WITH DPM CAUSE IT MONITERS EVERYTHING AND COMPINSATES FOR IT.
GOOD LUCK!!
