alright so i installed a new used carb on my 340 was wondering where to start with the tuning i heard to start about 2 turns out from all the way in on the mixture screw and then what about the other cable on the oppisite side of the throttle that runs down to the block area whats that for and how do i know where to have it adjusted...
on second note the choke cable does not exsist so how should i go about by passing that ?? the little round plug with a needle inside that moves up and down just bounces around in there is it supposed to be up or down or what in the diagram i looked at there is a spring that looks like it should hold it down??? anyways i can get it to run but its dogish and will randomly bog down and die .... any help would be nice thanks..
